thunderbird message pane does not "stay off" anyone have any suggestions
  • 4 replies
  • 3 have this problem
  • 7 views
  • Last reply by DebbyS
win 10 64 bit thunderbird 52.1.0 (32-bit)
thunderbird message pane does not "stay off" anyone have any suggestions win 10 64 bit thunderbird 52.1.0 (32-bit)
This typically happens when people let CCleaner mess with the Thunderbird profile. If you do that, stop it.
Read this answer in context 👍 2
All Replies (4)
I noted your response about CCleaner so I unticked all the options under Applications/Thunderbird. However the Message Pane continues to appear randomly. What next, please?
haroldf,
you posted to a 'solved' topic. Wrt your problem, please stick to the topic you started at https://support.mozilla.org/en-US/questions/1159617
Modified by christ1
Solution: I noted when I clicked View>Layout>Message Pane, and it didn't respond to unticking the thing so the Message Pane would stop displaying, it *does* have F8 beside it. Hitting the F8 key turned off the Message Pane. I don't know why I hit F8 while I was in Thunderbird, but either I did or the program just assumed I'd like to preview a message (I never do want to do that).
Hope this helps.
